Yesterday's Tractor Co. Tractor Parts for All Brands
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Painting Plows
[Return to Forum]
Larry Hardesty
07-25-2012 16:38:39
74.38.150.71
I have some fast hitch implements I want to paint, including a C-20 Moldboard Plow and a C-200 Disk Plow. I have looked at the Paint Committee decisions so I have some ideas.
Were the actual plow/discs painted when they left the factory? Mine mostly sit as ornaments, so any suggestions as what to paint the plow/disc part?
Thanks in advance
Larry Hardesty
[Reply]   [No Email]
Jim Becker
07-26-2012 12:04:28
173.74.120.222
Re: Painting Plows in reply to Jim R, 07-25-2012 16:38:39
Yes, it is an oil based graphite coating. Long after conventional paint would be dry, you can rub this stuff and get graphite on your finger. I never used it before, have no idea how it will hold up to weather or how it will act when you put the plow in the ground. I know that things like the spray wax for tools only hold up for a year or so. I hope this does better.Things like oil and gun grease only hold for so long too, how long depends on how thick you get it on.
  [Reply]  [No Email]
cleddy
07-26-2012 10:59:52
70.184.209.51
Re: Painting Plows in reply to Larry Hardesty, 07-25-2012 16:38:39
What are you talking about plow-coat? we always had a bucket of old gun grease around to paint the plow lays with a paint brush or rag wired on a stick. That was the kid's job. Sometimes the cows would lick it off then we got to do it again. Probably not something you would do for show.
  [Reply]  [No Email]
Jim Becker
07-25-2012 18:23:50
173.74.120.222
When your plows were built, IH probably coated the moldboards and disks with a colored varnish. The manuals said to remove it before plowing. I just finished restoring a plow and used EZ-Slide (by VanSickle) that I got at Tractor Supply. I assume it and Plow Coat are similar. From here, it was the nearest source for that sort of product. I may want to try plowing with it so didn't want to paint it. It should be easy to put more on if it needs it later on.
  [Reply]  [No Email]
sflem849
07-25-2012 20:18:03
69.197.84.39
Re: Painting Plows in reply to Jim Becker, 07-25-2012 18:23:50
I think the EZ-Slide is more of a graphite slip coat. The plow coat is a very soft easily removed paint...surface protectant.
  [Reply]  [No Email]
jack bycraft
07-25-2012 17:25:43
207.61.178.139
Harvester before it started using plow coat sometime in the early sixties, varished their soil contact surfaces after grinding. We purchased a c35 plow with rex bottoms 1961, it was varnished. What fun it was to get it scoured up!
  [Reply]  [No Email]
Nebraska Cowman
07-25-2012 17:37:04
166.182.3.123
Re: Painting Plows in reply to jack bycraft, 07-25-2012 17:25:43
That's what I was thinking, probably clear varnish. They'd have to be coated with something to prevent rust. When we sold Kvernelands plows the moldboards and shares were painted. We used paint remover and a putty knife before we delivered them.
  [Reply]  [No Email]
sgtbull
07-25-2012 16:54:24
163.191.228.254
I never saw a "new" disc plow sold, but I know that a good farmer would coat any plow w/ plow coat after it was scoured from use, and before it was stored. Kept the share ready to scour quickly on the next use. All the plow coat I've ever seen was black. Not a real glossy black, but not flat black either. I'd use a semi gloss black to make it look like plow coat, and may even brush it on, as that was how plow coat was applied.
Of course, if you thimk you're going to use it, then by all means, use plow coat! Plow coat is much softer than paint and comes off much easier, so which you use would be dictated by your plans for the plow.
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
