Yesterday's Tractor Co. We Have the Tractor Parts You Need
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Leaking rear main on an H
[Return to Forum]
Brad in WI
07-24-2012 19:36:12
50.116.173.122
I have a leaking rear main oil seal on my 1941 H. I want to get this fixed up as soon as possible but I am hoping that I don't need to split the tractor again. UGH! Can someone who has done this before tell me if I gotta split the tractor of if there is some trick to replacing the seal without splitting it. Thanks
[Reply]   [No Email]
rhtx55
07-25-2012 21:04:19
207.119.45.147
Re: Leaking rear main on an H in reply to Brad in WI, 07-24-2012 19:36:12
A leaking rear seal is usually an indicator the main & thrust bearing on the crank are just begining to wear. I have seen them with just the retainer coming loose and that is usually very lucky.
Drop the pan & plastigauge your mains. Take a dial indicator reading of the front to back crank movement, if they are within specs, it's probably the rear main seal retainer.
But to replace either, you will have to split the tractor.
How much oil is it leaking?
Does it leak most when the tractor is running or sitting?
This post was edited by rhtx55 at 21:05:12 07/25/12.
  [Reply]  [No Email]
Brad in WI
07-26-2012 02:57:46
50.116.173.122
Re: Leaking rear main on an H in reply to rhtx55, 07-25-2012 21:04:19
I haven't noticed if it leaks when it is running but it leaves a pretty good size puddle overnight when left inside on the concrete. There is not many hours on the rebuild of the engine and I have noticed that some of the bolts have loosened up on various other components on engine. My uncle did the work and he may have just not torqued the retainer bolts properly.
  [Reply]  [No Email]
sflem849
07-25-2012 04:37:23
69.197.84.39
Don't feel too bad Brad. I split my MD last winter to put a ring gear in and did the clutch and rear main "since I was in there." I put the upgraded seal retainer in and a new felt seal and it leaks terrible now and didn't really leak much before.
  [Reply]  [No Email]
Duanes
07-25-2012 13:03:54
136.234.40.2
Re: Leaking rear main on an H in reply to sflem849, 07-25-2012 04:37:23
Sflem can I ask where you got the upgraded retainer and seal for the job? What did you do to fix it the second time?
Thanks!
  [Reply]  [No Email]
sflem849
07-25-2012 15:13:43
69.197.84.39
Re: Leaking rear main on an H in reply to Duanes, 07-25-2012 13:03:54
I got the upgraded retainer from a friendly neighbor. On the MDs the retainer was white metal and on the 400/450 Ds it was steel. I still used the felt seal. Some say you can take the edges off the spiral groove and run the neoprene seal. I am not sure I am willing to risk that on an irreplacable crank.
  [Reply]  [No Email]
BruceS.
07-25-2012 04:29:32
76.15.9.253
Sorry...no possible way.
  [Reply]  [No Email]
sflem849
07-24-2012 20:12:50
69.197.84.39
Get your stands ready...
  [Reply]  [No Email]
Brad in WI
07-25-2012 03:00:38
50.116.173.122
Re: Leaking rear main on an H in reply to sflem849, 07-24-2012 20:12:50
The positive thing is that I haven't returned them to the owner since splitting the tractor earlier this month to put in a replacement input shaft to the transmission and a new clutch earlier this month. Seems like everything I do lately just has to be done multiple times.
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
