| Farmall & IHC Tractors Discussion Forum |
Topic: 48 M will not stay in 5 th gear
[Return to Forum]
| Author |
[Modern View]
| smcIND
07-21-2012 16:19:15
12.74.49.97
I know this has been addressed on here but I can"t remember the fix for this. I have a 48 Farmall M. I drove it from my Dads to my place today , it was the first time I drove it down the road for more then a mile, and it keeps coming out of 5th gear. What would be the fix for this problem. Thanks Steve |
[Reply] [No Email] | |
| smcIND
07-22-2012 16:52:41
12.74.50.0
Re: 48 M will not stay in 5 th gear in reply to smcIND, 07-21-2012 16:19:15
| Thanks to all of you I know where to start. It will alittle time before I can tear into it. I will let you know what I find out |
| sflem849
07-22-2012 15:38:17
69.197.84.39
| My H had a broken spring and a worn out gear.
I don't think anybody mentioned a worn out bearing on the top shaft. That will also make them jump out from what I have read.sd |
| CenTex Farmall
07-21-2012 20:53:49
173.166.205.41
| | Remove the belt pulley or cover plate (whichever you have) and you can readily see the area of interest. In addition to what CNKS said, there is the possibility of excessive wear in either the pilot bearing or the bearings in the input shaft assembly or some of both. Under load, the two shafts will be misaligned enough to allow the gears to "walk out". With the trans open, engage 4th gear and grab the front of the mainshaft and try to wiggle it around. Excessive play will be obvious. You'll be able to clearly see the splines on the inside of the 4th sliding gear and at the back of the input shaft. Try wiggling the input shaft as well. |
| smcIND
07-22-2012 12:42:11
12.74.50.74
Re: 48 M will not stay in 5 th gear in reply to CenTex Farmall, 07-21-2012 20:53:49
| When I remove the belt pulley will I have to drain the Oil? |
| Centex Farmall
07-22-2012 15:36:22
166.147.72.32
Re: 48 M will not stay in 5 th gear in reply to smcIND, 07-22-2012 12:42:11
| No, any mess will be minimal. The normal oil level in the trans is about half way up the countershaft and that's well below the part you need to look at. Just have a big piece of clean cardboard ready to set it on. Clean around it real good so dirt doesn't fall in when you remove it and be ready for the weight! It's located by two dowels and may take some prying and little wiggling to get it loose. |
| CNKS
07-22-2012 14:54:56
216.144.104.128
| Trying to remember if the pulley has a drain plug. The oil in the transmission is way below that point. Most of the oil drains back into the transmission, but it is still a mess to handle. |
| Zachary Hoyt
07-21-2012 17:42:30
74.47.48.18
| In addition to what CNKS said there is also a possibility that the shift fork is bent or the rail is worn and the detent ball is not able to hold it in place. Zach |
| CNKS
07-21-2012 18:11:00
216.144.104.128
Re: 48 M will not stay in 5 th gear in reply to Zachary Hoyt, 07-21-2012 17:42:30
| True. |
| CNKS
07-21-2012 17:24:51
216.144.104.128
| 5th is direct drive, the shafts are splined, one slides inside the other -- most likely the splines are worn, thus it won't stay engaged. Thus the shafts have to be replaced. I think you can see by removing the belt pulley, but to get the shaft and gears out you have to remove the trans cover, don't know if the belly pump has to come out or not, but the tractor does not have to be split. It also could be as simple as reshaping the bottom of the shift lever. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
