Yesterday's Tractor Co. Low Prices, Parts Ship Fast!
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Racing H: Update on the Update
[Return to Forum]
BruceS.
07-15-2012 13:09:05
76.15.9.253
First of all, thanks for all replies. I just finished doing what everyone suggested: Took off carb fuel bowl and checked throttle plate; not loose and closes with no binding; checked tang on throttle shaft; it is connected to carb and works freely; Adjusted equalzer on bellcrank so that throttle plate would close;all good; checked with disconnected linkage; couldn't see and problems;
checked movement of entire linkage with throttle handle; seems to work fine. Started tractor with throttle handle closed (and also throttle plate)
tractor raced so shut down immediaely. Where do I go from here: Governor lever seems to have "spring " in it, altho not strong. how can tractor run so fast with closed throttle plate unless governor is doing something right after starting. Appreciate any advice.
[Reply]   [No Email]
Jay Snyder
07-17-2012 17:39:42
70.92.235.82
 Re: Racing H: Update on the Update in reply to BruceS., 07-15-2012 13:09:05
Have you checked the gasket between the carb and manifold? If the gasket is bad and doesnt seal it will suck air past it and the tractor will race. It basicually takes the throttle away from it. It will suck the air and it will pull the fuel up out of the carb. Check that first it is the cheapest and easiest. Good luck Jason
[Reply]  [No Email]
Brett Helmkamp
07-16-2012 07:19:26
67.236.72.7
I had a 300 that was racing and I believed it was in the gov. I disconnected the linkage to the gov so it would come all the way forward and it ran great. Someone had the wrong linkage in it. I made one that was correct and fixed the problem. They had removed any adjustment rods in all of the linkages. I used some smooth rod and threaded the one end and used a yolk that I had lying around and was all good after that. Just a thought.
[Reply]  [No Email]
pete 23
07-15-2012 19:56:21
74.32.238.2
Often time guys get into that governor and think they can increase the rpms of engine by making that link longer. No such luck. The weights and spring tension balance out to control speed. Harder the spring pulls on internal lever, faster engine will run. That link vertical adjustable link is to be adjusted so when gov weights are fully collapsed the throttle plate in carb is fully open, straight up and down. To adjust, take pin out, pull throttle lever wide open, pull up on lever that goes to carb, and then adjust the length of the rod clevis so pin just fit in.
[Reply]  [No Email]
Brownie 450
07-15-2012 15:14:05
66.43.241.198
The weights work against the gov spring to slow it down. The spring should be the only thing opening the throttle shaft. Are the weight "fingers" engaging the proper area in the gov?
[Reply]  [No Email]
rustred
07-15-2012 14:09:26
184.151.222.96
you need to remove the cover with the 2 screws on the governor and hold the rod it in the closed position while someone starts the tractor. i appears as soon as the tractor starts the governor is wide open.
[Reply]  [No Email]
BruceS.
07-15-2012 15:03:47
76.15.9.253
 Re: Racing H: Update on the Update in reply to rustred, 07-15-2012 14:09:26
Did as you suggested. Took top cover off and held down the rod goin to gov and she idled right down. When I held it down, it took all the slop out of the linkage. The stop nut on the rod was only down about 3/8 of an in. I'm assuming the rod is adjustable since it has a lot of threads on it. Someone was in there before. There's a brand new cotter pin in the pin that holds the throttle shaft.
Could it be that whoever worked on this didn't adjust it correctly?
[Reply]  [No Email]
DonR of Mn
07-15-2012 17:53:05
173.143.242.222
 Re: Racing H: Update on the Update in reply to BruceS., 07-15-2012 15:03:47
It sounds to me what you need to do is get an "IT" manual and go the section on adjusting and setting the trottle and carb linkage. It is a simple procces. But a little hard to tell how to do here. With a manual it show what parts are what and what order to set every thing. I just did it to my 650 Gas and with it done by the book it all works right. From what I have read here everybody is kind telling you parts of procedure, but not everything at once. Get the book if you don't have one start from scratch.
[Reply]  [No Email]
BruceS.
07-15-2012 18:26:51
76.15.9.253
 Re: Racing H: Update on the Update in reply to DonR of Mn, 07-15-2012 17:53:05
I do have an IT manual. Don't know why I didn't consult it earlier. I just went thru the adjustments shown in the manual, but it didn't come out exactly the way the manual says. For example, the clevis on the gov. rod was already adjusted down as far as it would go, and should go farther to line up with connection with throttle shaft. It supposed to be adjusted with WOT. I got as close as possible to what manual says, and actually got the engine to idle on its own for about 5 minutes, but then it started revving up again. Almost acts like the governor is sticking, but WHAT is sticking, I don't know.
[Reply]  [No Email]
rustred
07-15-2012 18:34:50
184.151.222.96
 Re: Racing H: Update on the Update in reply to BruceS., 07-15-2012 18:26:51
have you checked the weights where the pins go, i have seen those holes worn right out and cause the weights to stick. you may also need to adjust the linkage from hand throttle to governor to get proper adjustment at throttle shaft lever.
[Reply]  [No Email]
rustred
07-15-2012 15:24:52
184.151.222.96
that is correct, i relized that when you said you had a lockwasher on the speed adjust. the adjustment starts right there at that rod. you need throttle lever wide open then remove the pin next to the rod. then hold the throttle shaft lever and the adjusting block up. if the pin will not go in adjust the block with the rod till it goes in freely. now you are adjusted in w.o. t. now fine tuning is next.
[Reply]  [No Email]
rustred
07-15-2012 14:22:42
184.151.222.96
another thing is the weights may be so badly worn that they are jammed in the outward position. need to remove cover and have a look in there.
[Reply]  [No Email]
The Red
07-15-2012 14:27:55
69.246.205.0
 Re: Racing H: Update on the Update in reply to rustred, 07-15-2012 14:22:42
I think we are getting there. Governor assembly seems to be the culprit.
[Reply]  [No Email]
The Red
07-15-2012 13:12:59
69.246.205.0
Have you adjusted the bolts/nuts on the governor lever? They do get loose. Did you replace the governor spring?
[Reply]  [No Email]
BruceS.
07-15-2012 13:22:19
76.15.9.253
 Re: Racing H: Update on the Update in reply to The Red, 07-15-2012 13:12:59
Thanks Red. No, I haven't even had the gov cover plate off. One additional thing: when I was trying out the throttle linkage, i found that there is no resistance when putting in wide open position. Does that indicate a weak spring?
[Reply]  [No Email]
The Red
07-15-2012 13:37:58
69.246.205.0
 Re: Racing H: Update on the Update in reply to BruceS., 07-15-2012 13:22:19
More than likely yes. I think I have replaced that in every single Farmall H and M I have worked on through the years. The 1951 H I rebuilt in 1999 (article is on this site) took off like a scared jack rabbit when I started it after the rebuild. Got broke in real quick!!
[Reply]  [No Email]
BruceS.
07-15-2012 14:11:13
76.15.9.253
 Re: Racing H: Update on the Update in reply to The Red, 07-15-2012 13:37:58
Thanks again. I just took off the governor plate and found that the set screw (bolt) on the speed lever very loose. Tightened it up and used a new lockwasher. Restarted tractor but it still speeded up. BTW, The whole gov. assembly seems very "relaxed" (including spring) when throttle is in closed position. Is this the way it's supposed to be? I reread your article on your 51 H and you mention adjusting the "High speed bolt" Which one is this and which way does it turn to lower rpms?
Thanks for answering.
[Reply]  [No Email]
The Red
07-15-2012 14:27:00
69.246.205.0
 Re: Racing H: Update on the Update in reply to BruceS., 07-15-2012 14:11:13
Bruce I found my manual. The lower bolt is the high speed bolt. Screw it in to slow down the engine RPM. I am guessing around 1/2 inch should protrude left beyond the lever assembly. Upper one is the idle speed about 3/8 inch protruding. Should get you in the ballpark.
[Reply]  [No Email]
rustred
07-15-2012 14:47:03
184.151.222.96
 Re: Racing H: Update on the Update in reply to The Red, 07-15-2012 14:27:00
the speed screw is to just contact the stop when throttle is in wide open position.it is locked with a NUT on the threads, not lockwasher. yes it is relaxed when engine not running. once running the wieghts fly out and hold the throttle.
[Reply]  [No Email]
The Red
07-15-2012 14:52:11
69.246.205.0
 Re: Racing H: Update on the Update in reply to rustred, 07-15-2012 14:47:03
I think we have found the culprit which seems to be in the governor assembly.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
