Yesterday's Tractor Co. New Parts for Old Tractors
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Farmall Super M
[Return to Forum]
Pat Connors
07-11-2012 08:20:24
192.223.243.5
1953 Super M compression test shows cyl1: 121psi, cyl2: 118psi, cyl3: 118psi, cyl4: 121psi. Book says 129psi is best. Bluish smoke and some minor blow by. Maybe rings? Could I get away with using 20w50 oil instead of the SAE30 that is in there? Would that help with compression and help to stop burning the oil? Or should I just do the rings/?
[Reply]   [No Email]
mkirsch
07-11-2012 10:26:50
64.80.110.74
 Re: Farmall Super M in reply to Pat Connors, 07-11-2012 08:20:24
Compression is fine. You don't need to start thinking about doing anything to the engine internals until compression gets down around 75PSI.
I can speak from experience, going to "thicker" oil makes NO DIFFERENCE, period. Doesn't help oil pressure. Definitely doesn't do a thing for compression.
You might have some oil coming in through the valve guides.
Work the snot out of it if you can.
Another option is to get it warmed up and spray 1/2 of a can of Seafoam directly into the intake with an old Windex bottle as quickly as you can without killing the engine. Should clean it up.
[Reply]  [No Email]
robgIN
07-11-2012 09:46:09
70.224.39.105
what you are looking for with a compression test is consistency among cyls, and it don't get any more consistant than that. The valves have to be pretty good too or you would have more spread in the numbers. Put some clean oil in it and make it work, chances are the more and harder it works the rings will seat and it will clear up. If not , with those numbers I would think it has to be getting oil through the valve guides if its burning it.
[Reply]  [No Email]
robgIN
07-11-2012 09:46:02
70.224.39.105
[Reply]  [No Email]
DeltaRed
07-11-2012 08:55:50
67.6.240.195
Those kind of numbers-Leave it alone!The rings are probably just stuck/glazed from sitting,idleing/poopin' around.If it was not properly 'broken in' after the last OH,it will smoke.I dont think "thicker oil" will work.Work the snot out of it for a couple days or so(get the engine good and warm for a prolonged time).Try putting some 'Restore' in it,that sometimes helps.Another possibility is valve guides.Just my humble opinion,Steve
[Reply]  [No Email]
rustred
07-11-2012 09:20:21
184.151.222.55
 Re: Farmall Super M in reply to DeltaRed, 07-11-2012 08:55:50
agree, it just needs to be taken out in the field and worked under load. first change the oil if its dirty or due and throw in i quart auto trans oil in it and put it to work. then next oil change 20-50 is fine.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
