Calling Rustyfarmall
BigTone
I got the valve grind gasket kit from you, any idea what the 2 washers in the kit go to? Thanks, anthony...
(quoted from post at 04:51:33 07/08/12) Copper looking things? Valve cover bolts.
Yep. They go under the nuts that hold the valve cover down.
You might also want to look at the top of the valve cover. The area where the studs come through is supposed to be nice and flat. If a previous mechanic has over-tightened the nuts, that area will be concaved and will be difficult to keep from leaking. Turn the cover upside down on a flat block of wood, and then use another long piece of wood and a hammer to drive the concaved area back to where it is flat once again.
