joint at the front of trans on A.
blunted
the old coller washers are good but rubber inside are falling apart. can you take mud flap rubber and make just a flat peace on both sides and flat washers, the same thickness? and the metal plate,in between the bolt holes are worn and slite whabbled, will the plate be ok, or make new one, drilled for tight fit with the bolts? thanks.
I would have to check the joint I have on the B parts rear end to tell you if you could get by with that or not but right now it is to dark out for me to look LOL
Take the plate and hammer the holes to get the ridges down if they are enlarged the tapered bolts should not have a lot of play any rubber and washer will work. I did get new washers from i-h. That shaft isnt a realy big deal as the bearing on the front of the tranny keeps the shaft in line and how often is the engine running 1400 rpms.
The last time I checked with IH they could get the rubber washers but then again it was a young kid looking things up.
I know a guy in Wisconsin that has alot of parts and pieces he may have what you need.
Here is his number. 1-920=787-7635. ask for Gene.
He is a real good guy!
