04 Orchard tractor tires
Wondering what you are putting under the 04 tractor as far as rear tire size goes. I have been searching for an answer, and have been informed of a couple different possibilities. Some say to put 14x9x26 or 13x6x26. Want to make sure it is back to original, but have been told concerns with the tire clearance if I use 14"s. What is the correct size, and then has anyone put new tires on your 04 tractor and what size were they? Thanks for your comments, and you can call me direct if you want to share your thoughts. Lenny-309-738-1170
Mine has 13-6x26 and I think it looks good. The bigger tires I think would be to big but it's up to you. stumper
Standard tires on the O-4 tractor were 5:50 x 16 front and 12 (13.6) x 26 rear. Optional from the factory were 6:00 x 16 front and 13 (14.9) x 26 rear. (Taken from 1951 specs).
Harold H
