Yesterday's Tractor Co. Compare our Prices For Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: H Wiring
[Return to Forum]
j hakenwerth
06-20-2012 03:54:35
69.179.191.50
I just replaced my wiring, I thought I followed Bob's diagram, but must have made a mistake. When I turn the lights on the Ampmeter says charge' not discharge? Also when I pull out the on off button the ampmeter gauge does not move.
Thanks for any help
Jerry
[Reply]   [No Email]
j hakenwerth
06-21-2012 05:33:20
69.179.147.168
Re: H Wiring in reply to j hakenwerth, 06-20-2012 03:54:35
Thanks guys, everything is working right now. I reversed the ampmeter wires. after i started the tractor the next time and turned it off, and then pulled the switched it showed discharge.
  [Reply]  [No Email]
Owen Aaland
06-20-2012 15:47:29
216.47.35.138
Re: H Wiring in reply to BruceS., 06-20-2012 03:54:35
Do you have an alternator on your H or M?
An H or M originally would have no other draw on the electrical system going through the switch other than the coil. The points are merely another switch in the wiring circuit. Unless there is a short some where there will be no draw on the circuit except when the points are closed.
  [Reply]  [No Email]
wayne in mn
06-20-2012 04:41:18
24.179.175.110
1. Reverse the leads on the ammeter.
2. If you have a magneto, the ammeter will not move.
  [Reply]  [No Email]
j hakenwerth
06-20-2012 05:30:54
69.179.191.50
Re: H Wiring in reply to wayne in mn, 06-20-2012 04:41:18
Thanks Wayne. I do not have a magneto
  [Reply]  [No Email]
Bob M
06-20-2012 07:35:26
69.207.87.163
Re: H Wiring in reply to j hakenwerth, 06-20-2012 05:30:54
Jerry - that's an easy fix: Find the wire running from one an ammeter post to the "hot" side of the ignition switch. Relocate the ammeter end of the wire to the opposite ammeter post.
This should get your ammeter working correctly!
  [Reply]  [No Email]
eye4iron
06-20-2012 13:30:35
199.38.133.55
Re: H Wiring in reply to Bob M, 06-20-2012 07:35:26
If your points were open there will be no drain shown on the amp meter when the switch is pulled out.
  [Reply]  [No Email]
The Red
06-20-2012 15:21:28
69.246.205.0
Re: H Wiring in reply to eye4iron, 06-20-2012 13:30:35
I would disagree with that. My Hs and Ms always show a bit of a discharge on the ampmeter when you pull on the coil switch regardless of the points being open or closed.
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
