TylerFarmallH
I converted my 46 farmall H to 12 volt thanks to help from this forum.
Strangely enough now that the conversion is working I noticed its idling rough. Is this common after a 12 volt conversion? Is the change in the electrical affecting the ignition and is it now requiring an adjustment?
what should I check first? It seems to be running with an uneven sound compared to before the conversion. It doesnT really even out at higher rpms either....
