Problem with jet behind load screw on a SH carb. Its a .061 size and fuel to rich unless load screw almost bottomed. Not many SH around these parts so I wonder if anyone ever installed a 3-9/16 bore original fire crater kit in one.
Did they come with a bigger jet to install in the kit? Or just use the original jet? Even if they did I don't think they would jump from a .046 size up to the .061. Kind of looks like it was drilled by someone. Since the engine has the fire craters I don't know if I should drop back to .046 or in between. Thanks for any info.
