Farmall 300 oil pressure
Anonymous-0
When I start my Farmall 300 the oil pressure is 60. After she heats up (30 min)she goes no lower than 20. Is this ok? Could it be the bearings or the pump? Thanks
That is plenty of pressure. I have one M that drops down to 5psi when it is warm at idle, around 20psi mid throttle.
That is a lot of drop, but it all depends on if this is something that just recently happened or if it has been doing it for a long time. It is definetely not a normal situation for a lube system in good over all condition. Could be leaking pressure relief valve, general worn out oil pump, excessive clearance on end plate of oil pump(blown gasket) general loose mains , rod, cam bearings or it could indicate one failing or failed bearing, so , like I said , depends , has this just suddenly happened.
It sounds a little low and check gauge to see if its good before tearing into anything. I have a M and 450 and they both run 70 to 75 lbs. pressure cold or hot.
bearings getting worn
10w-30 is a little thin for worn bearings.
15W-40 diesel rated oil will pick it up some if worn.
Put rod and main bearings on your future to do list.
not hard, and you can put a new oil pump cover gasket and
relief spring(if applicable on that motor), and plane the cover
when you are in there.
with that said, I've had tractors that dropped worse. no problems, I
just knew that I would have to roll in new shells when I had the time.
You are fine.
20 PSI at operating temp on a 1950s tractor engine is actually pretty good. 30 PSI was common when new - at opearing temp, after 50 years of use I wouldn't be surprised if you don't have 10 psi lost in just the gauge not measuring it accurately.
