Little Genius plow hydraulic conversion
I recently picked up a 3 bottom Little Genius plow with clutch lift. Included was a complete, never installed hydraulic conversion bracket. Can this be installed so the plow can be easily switched back and forth between mechanical and hydraulic lift? Anybody have the installation instructions for this conversion? Thanks.
you could switch back and forth, but I don't know how easily. The land side lever is removed for hydraulic conversion. I've got a 3 bottom with that setup. Here's a few pics for you that may help.
I've got the instructions at home, but no way to scan them... Maybe I can take hi-res pictures.
As to easy, depends on your definition of easy. By my definition, no.
The pictures are great. I didn't want to do the conversion if cutting and welding was involved, but this looks all bolt-on. I don't plan to flip-flop betweeen hydraulic and mechanical. I just want to return the plow to original mechanical lift someday - maybe. Thanks for the help guys!
Ok if that's the case then your biggest challenge will be to not lose the parts you take off the plow!
oops, yes it is. it was on it when I bought it. some dern fool will probably pay good money for it so I can get a nice proper red one on it one of these days.
