Farmall H vs M loop drawbar differences
Schultz
I'm sure this has been asked before but what are the differences in the loop drawbar between an H and M? If anyone knows of a staight M drawbar available I'd be interested, mine is pretty mangled.
Thanks,
Only in thickness of loop From 3/4 to about an inch on the M. Other dimensions are the same. The drawbar is much different and not interchangable. Jim
(quoted from post at 10:45:18 04/23/12) I'm sure this has been asked before but what are the differences in the loop drawbar between an H and M? If anyone knows of a staight M drawbar available I'd be interested, mine is pretty mangled.
Thanks,
The U draw bar will interchange. The M swinging drawbar is thicker and won't fit the H under belly. An H swingdraw bar will fit the M, but you must use the H draw bar belly pin.
