Luther
Need to find where I can get my carb beefed up a little. It lags a little when pulling in th 10,000 # class
The eng has a big bore high dome pistons . Thats all that was done to it. ( SO FAR ) I had not planed on doing any thing else.
you can change the venturi to a late 400/450 one this will help the bottom end. At this point going nuts with the carb will not help too too much. Getting a cam grind would be a better option to me.
Andrew
