Some time back I posted about my fast hitch cylinder not staying up. Well I finally got around to investigating the problem. When I took the cylinder apart I was greeted by a pitted cylinder wall and top of piston also being pitted. The wall is so bad in one place I'm surprise it has not eaten all the way trough the wall. This tractor had the lines unhooked when I brought it and some kind of air fitting hooked to it? I can get a cylinder from a 560 from a friend. My question is will a cylinder from a 560 work on my fast hitch? It has traction control. I don't think my cylinder is rebuildable. Thanks Josh
