Farmall F-20 rear width with 11-36 tires
Jim R
I have a friend that needs his Farmall F-20 brought home from out of state. I was told that the rear tire width is not adjustable. I was wondering if anyone out there could tell me what the width of the rear tires was, outside to outside, with 11-36 tires on it. Just trying to find out if it will fit on my trailer. Thanks for your response!
Also forgot to ask, does anyone know what this tractor will weigh with no fluid in the tires and a narrow front end?
This was just brought up a day or so ago. Weight about 4000# Some one said width was 96". I think mine was closer to 98"-99". A narrow tread rear would be less. oldiron29
my narrow tread on 11-36 rears is about 49" inside to inside and about 75" outside to outside of tires, add about a foot to that for wide tread so you will most likely be 86 inches at least unless it has cast rear wheels with the rims set in . Weight will about 4500#.
I have a wide rear F-20 on rear cast also and with the rims set in as far as they go it is about the same as my narrow tread on 36" cutoffs. When you get them on 28" rears is when they get REALLY wide
I have had more peaple ask if mine was a narrow because the wheels are in that far. It does make it nice to take to shows because if fits on a regular car trailer real nice.
