400 Farmall distributor drive lube ?
Jon Hagen
Working on a 400 Farmall with the "live" hydraulic pump between the engine and distributor.
what lubricant lubes the distributor drive gears and how much goes in that little housing that adapts the distributor to the hydralic pump ?
There should be a grease fitting there or a slotted screw to put one in. Pump a bunch of grease in there , then a stroke at oil change time. There also is one to lube the dist shaft. That one doesn't take much & will come out the back side.
