Dave Meisner
Hi. I am in need of some advice. I can not start my wd9. It has gas in the carb, but wont suck gas into the intake manifold. I pulled the manifold off and the butterfly valves look fine and seem to be working properly. I plugged the large holes in the head to simulate what the compression lever does when you are starting it on gas, and there is suction in the small holes like it should be. I don"t know how much pressure it needs to suck gas, but there was suction. Any ideas? Also wondered if it would be ok to try to start the tractor on diesel without starting on gas first. Could this damage the head? Thank for your help!
