Will a 560 fast hitch fit an M?
BigTone
Just found out that the 3 pt. hitch off the 560 is actually a Fast Hitch converted to a 3pt. hitch...I think it also has a bar that looks like it bolts to the draw bar, maybe traction control?
Will this bolt to the axle of my M or do I need to build these templates I have been hearing about? Any help would be greatly appreciated...
If what you are looking at is a factory 560 fast hitch, it will not fit a M, The M rear end is not drilled and tapped for the mounting of the hitch.
If you look farther down in post,this was asked earlier.There is a pic of it.
You would have to build mounting brackets for it fir the rear axle.
