Just mounted a loader on my 1963 IH 706 and it's not working quite like I expected. First question, I'm using the side remotes on the shifter side then running hoses to the loader valve. Is only one of the outlets pressure? For some reason it only works w/ the tractor control lever pushed rearward. Shouldn't it work opposite just by swapping the hoses on the remotes?
Second question, there's a fairly loud squealing whenever the loader is working very hard and it doesn't seem to have enough power to lift up the front of the tractor. That's not normal is it? I know the rear remotes work well b/c the 3pt (aftermarket that plugs in the rear remotes) has enough power to pick up the rear of the tractor.
