Picked up the 756 last week that I had asked some questions about on here. Yesterday I aquired a JD 148 loader. I am going to have to do some bracket alterations, and I would like some input on the best way to mount it. I was thinking about bolting it to the clutch housing, then along the frame rails, then to the front of the tractor. Will this be suitable? I do not want to crack my clutch housing. I may also consider going to the back axle but I would prefer not to. The loader and mounts came off of a JD 4020. Have not had a chance to look at it enough to see if I can just drill new holes in the side plates or have to start from scratch. My plan at the moment is to do away with the square tubing that runs to the front and replace it with 1/2 inch steel to bolt to the frame rails. Open to any ideas.
Thanks,
Mark
Thanks,
Mark
