Help !! IH 756 Gas, i NEED pics to put back together !!
Here's the scoop on this tractor.
The tractor needed to be overhauled so the hired man torn the motor off and we sent the engine in for a overhaul.
Before we got the motor back the hire man got hurt at home and never came back. So someone else needs to put it back together but don't know where some of the parts goes on.
So if someone has pics of the Farmall 756 Gas please help me!!! Thank You So Much
This something you should not attempt alone.Hire a pro.However if you must, buy a book(s) and READ them before yoy pick up a wrench.Good luck.Steve
I can get it back to together pretty much but like to see if someone has a pic restoring there tractor so i know the correct way the wiring went and certain clamps etc. I just like to get it back together as close as original. Thanks
(quoted from post at 09:08:01 02/11/12) I can get it back to together pretty much but like to see if someone has a pic restoring there tractor so i know the correct way the wiring went and certain clamps etc. I just like to get it back together as close as original. Thanks
The owners manual has a very good wiring diagram.
If ya were close to me it would not be a problem . As i have done enough of them on a restless night i could do it almost in the dark. I am in N. E. Ohio
