i have a nice set of fast hitch plows i picked up but not sure the model the frame looks like 311 but the hitch is not solid mount it has a hydraulic tail wheel and depth wheel on the side they are 3 14 inch
thanks dan
Could be a 312.
Models 2/3/4/511 plows were fully mounted 2-pt hitch plows.
Models 3/4/512 plows were semi-mounted 2-pt. hitch plows.
With these plows, the first number in the model number was the number of bottoms.
I think 412 plows could also have the rear bottom dropped to make it a 3 bottom.
Early 3/4/512 plows used an arm bolted on the tractor hitch, a chain and linkage to control the rear wheel. Later ones got a hydraulic cylinder.
AG
I have a 3/16" 535 semi mount that the book shows 3 point or fast hitch.Should be just right for Old Stinky 460D.Bud.
If it is not solid mounted, and there is a hydraulic tail wheel, then it is a "semi-mounted" plow for future reference.
yuppers thats it thanks alot mine look really nice just needs paint job to compare to that
thanks again i was gonna head out in the day light to get pictures but this worked perfet
