LarryM
What would a Super W6 with a automotive quality paint job, tight steering, live hydaulics, everything correct as far as the seat ignition & sheetmetal, and brand new firestone field and roads be worth? It is a later Super W6 with the frame rails. It also has a set of weights. Everything about the tractor is in excellent. Not low hours but excellent. Thanks fo your help.
hard to say without a pic. it has 1400.00 worth of tires. so it can be from 2500.00 and up. and are you buying or selling. all depends on the paint job and if it has decals installed and the attractiveness of it.with out a pic. , just shooting in the dark.
It has to have more than paint. If no engine or transmission work was needed, at the least all other seals and gaskets should have been replaced. I replace all seals and gaskets, leaking or not, most do leak anyway. Also the brakes and clutch and brake shafts should have been replaced. If that was done on the SW6, I would probably ask a minimum of $3500.
Minimum of $1,400 because of the new rear tires, and maybe another $1,000 because it runs good and drives. The automotive quality paint does not add any value. I would much rather buy one in NEED of paint.
