Anonymous-0
Might be a stupied question but I am guessing the firing order stamped into the block of my B414 tractor which is 1342 with 1 being at the battry/gas tank and 2 being at the radiator. I was told 1 was at the radiator but the block is marked out as such.
If i go in a circle starting with #1 at TDC at the gastank end of tractor I should then work counter clockwise with number 2 coming from the front of tractor(rad) number 3 comming from the middle closer to (tank) and number 4 comming from the middle closer to the (rad)
Does this sound correct or am I missing something??
