oldtanker
I'm going to be looking at one this coming week. Any tips? Would be used for lite field work and running a haybine.
Rick
I have two 560d .They need 6 good glow plugs to start well and not to puff white smoke some will a little tell they warm up some.Of course the TA good on low and high side.Im lucky my TA's work good but many, the low sides are out which means a double split and a new sprag instaled.Most generaly the high side works and you can still use the tractor that way.Too check the low side put in gear drive forward apply the brakes and pull the ta lever back if it stops she is out.560's got a bad rep but have had good luck with mine.
