806 wheatland front wheel hubs
Guys I am trying to fit 11l-16's on the front of my 806 wheatland and my 8 bolt hubs won't work, I need a hub with a little more offset to the ouside, The current ones I am trying to use are causing the rims to hit the axle legs, anyone know which hubs I will need to make this work?
Thanks, junky
I beleive you will have to buy rims with more offset.
You can also try turning the rims you have around, The valve stems would be on the inside and the correct police may complain but it works.
Don't know if you can even buy hubs to change the offset.
Gary
can I suggest that you take you check book to you local Ag service business and leave a blank check. They should be able to get you what you need in no time. :D
A correctly milled and drilled plate would allow as
much a 3/8" of added space. It must be capable of
centering the wheel on its inner diameter, and the
hub as well. Longer studs might also be needed to
assure full thread engagement. Not the best if
using a loader. (not likely on a W series) Jim
Ummmmm, I have done that too many times Stacy!
I have 2 different offset rims and neither will work, not sure how many options are out there or if there were different vairations of hubs???
