504D fuel leak
dahlia21122
New User
I have a Int'l 504D with a Roosa Master injection pump. It has a manual shut down cable. The fuel is leaking around the shaft that goes into the pump housing. When tractor is sitting in shed it drains the tank dry. Easy fix? O-ring? Any help would be great Thanks, Andy D.
If pump has never been off, might be time for complete reseal. Call 574 893 4172 if you like after 7 PM, can explain better.
My 504 has not started leaking there, but my Allis Chalmers 180 has. BUT. Only when the fuel cable is in the RUN position. I fear it needs an O/H.
CT
