Cub Crank pully
OH several Farmalls in the past but currently on the Wife"s Cub. I will post several questions seperately to help keep me straight. First, what Kind of puller do I need to remove the Crank pully? and how will I re-install it once I'm ready to build it back? Thanks in advance for all you help!
To remove, follow this link. You can use a bearing puller as well.
[b:4474800698]http://www.farmallcub.com/phpBB2/viewtopic.php?f=141&t=34545[/b:4474800698]
To install, clean up the crankshaft, thread in a piece of all thread into the crank, get the pulley lined up with the keyway, then with a piece of plate with a hole in the center, slide over the threaded rod and with a couple greased washers and a nut, slowly pull the pulley back on till it's fully seated. Some people heat them up, but I've never had to do it.
I"ve always put the pulley in my oven and heated it to 350 for about 30 min....then put it on quickly.. makes them much easier to install.
