15.5x38 on an M?
BigTone
My brother in law is giving me his 15.5x38, rims, and centers off his 560 to put on my M. Anyone run tires this size on there M and are there any issues? they are goodyears mounted on 560 rims so hes giving me the centers because they mount up the same.
I beleive that 13.6 is the normal size on a M and if I am not wrong the 15.5 is the same height as 13.6 so your ground speed should be the same with more rubber on the ground for better traction.
Bob
If you want to make that M look right you should get regular M 12 inch wide rims and 13.6 or 14.9-38 tires....But the 560 wheels and 15.5's will work fine...depends on what you want I guess...
