Farmall Power Unit?
tmiller
Is this a farmall power unit? i found it at a local junk yard, will all the parts on it (except the gas tank fit my letter series?
<a href="http://s276.photobucket.com/albums/kk5/tmillerfarmequipment/?action=view&amp;current=photo-2.jpg" target="_blank">
photo-2.jpg" border="0" alt="Photobucket
</a>
Thanks
Taylor
Taylor; It has a very small Continental engine . I have one just like it, it is out of a very old I.H.C. baler.----------Harold.
It does use the I-H mag but the base is rotated some. Carb is for a 69cuin engine and radiator is different so there realy arent any parts that just bolt on without doing some changes. But that engine shouldnt be scrapped if i was close i would buy it just to make it run someone would like to have one. Does it have a clutch as some did. The ones used on the combine did have clutches baler usually didnt.
<a href="http://s276.photobucket.com/albums/kk5/tmillerfarmequipment/?action=view&amp;current=powerunit.jpg" target="_blank">
powerunit.jpg" border="0" alt="Photobucket
</a>
so hardly any of these parts will work...
how many cubic inches would the blok be?
<a href="http://s276.photobucket.com/albums/kk5/tmillerfarmequipment/?action=view&amp;current=powerunit-1.jpg" target="_blank">
powerunit-1.jpg" border="0" alt="Photobucket
</a>
If it is a 4 cylinder, and it looks like it may be, then it would probably fit in a Massey Harris Pony.
Mine carries a 4 Cyl. Continental
