Anonymous-0
Working on issues with a IHC B414 that does not want to run, tested compression 145 - 150. Does not appear to have manifold leak good suction on intake and strong exaust pressure.
With a in line spark tester I get the following result on each cylinder
Turn key from off to run, very tiny weak flicker, turn to start and through four counts : 1 weak , 2 weak , 3 weak , 4 dull strong spark.
Do I have spark ignition issues here, what should the point gap be set at
