Anonymous-0
I recently bought a 1958 F 560 with a loader. It had bad bucket cylinders - gushing milky hyraulic fluid, I had the cylinders repaired and was advised to purge the system to eliminate water contamination. I drained the system -- it had only two or three gallons. Not wanting to waste money, I twice cycled the system with fresh fluid -- once with 7.5 gallons and a second time with 5 gallons. The hydraulic fluid is still milky. It occurs to me that the system is probably putting air into the fluid because it is low on fluid making it milky.
I would like to know what someone more experienced thinks before I put 16 gallons of Hytran in the system. Thanks. jim
