Anonymous-0
I want to change oil in the touch control on my C farmall. Do i need to use HY TRAN or is any good hydraulic oil good enough? thanks Jim.
When IH first invented the system, the recommendation was SAE 10 motor oil -- so it is not sophisticated. You can use any universal trans/hyd oil that meets hytran specs.
Thanks guys, the reason i asked, is because the owners manual says to use I H touch control fluid and i knew they probably didnt have such a thing any more. Jim
