wrong wheel for tractor for cboxca
CAROGATOR
cboxca you are looking for a wheel for the rear of
a Super C. It carries the 6 lug and a regular c uses 4 lugs. hope this helps.
Really??I thought all C/SC were the 6 lug wheel.I just learned something!This just proves once again that "TractorTalk" is educational!
Don't know where that info came from, all C's and Super C's came from the factory with 6 lugs on the rim. The A,B, BN have 4.
Just going by the parts listings on this forum. and
cboxca was looking for a 6 lug rim for his C . Who can say what is reality?
The wheels from C through 240 row crop will interchange and all were 6-lug. Farmall made one more model (404 I believe) that will also take the same wheel.
The parts listing on this website is WRONG.
It lists the same rear rim for A, Super A, B, BN, C, 100, 130, 140. A 9x24", 4-lug rim.
Whoever was doing the data entry for that particular part got "on a roll," blindly went through the alphabet, and didn't check their work.
This site does not sell a rear rim for the Farmall C, Super C, 200, 230, 240, or 404 tractors.
The correct rear rim is a 36" diameter, 6-lug.
I just went on google, typed in "Farmall Super C rear rim" and got a whole bunch of promising hits... I don't believe for one second that he actually TRIED to find a rim because if he had put forth the least bit of effort, he would've found it easily... Steiner's, Restoration Supply, Wengers, Unverferth, ebay, Amazon... all from a simple google search.
