Farmall H push rods
About three years ago I purchased an H from my boss tractor runs and drives good. Recently I was doing some work under the hood and I drove it with the hood off. Noticed some oil leaking out of the tappin cover, Pulled cover off to find gaket shot... Also upon further inspection noticed that 5 out of 8 push rods had minor to major bends in them. I am wondering about putting new rods into and old engine if this a good idea or a no no. Thought about straightening them but not even goin to try that. Anyone let me know what you think. Thanks in advance.
If you don't have a good anvil. drive to the nearest railraod and lay them on the track and straighten with a heavy ball peen hammer.
Be sure and adjust the valves (017) warm summer day temp.
(quoted from post at 17:23:31 09/26/11) If you don't have a good anvil. drive to the nearest railraod and lay them on the track and straighten with a heavy ball peen hammer.
I'm of the same thoughts as Gordo other than the warm, summer day. You can work on your tractor any time of year. :lol: The book says to adjust them to .017 with engine at operating temp. That is a little difficult to do so I generally set them at .016 cold. The old Cases were notorious for bending rods in the field. My neighbor is a Case man and he said they would pull them in the field and straighten them on the drawbar. If Zach has a set I would certainly put them in.
Try that in this area and you're likely to have a bored Homeland Security agent shoot you in the back!
