'41 still smoky
Cory Bernu
08-21-2000 06:31:24
The Red. I turned the idle mixture screw in until I heard a change then backed it our 1/2 turn. The high speed screw needed to be turned in about 1 1/2 turns before it started to sputter. So now the high speed is set 1 1/4 turns from all the way in. Any thoughts?
ken
12-25-2002 20:11:25
 Re: '41 still smoky in reply to Cory Bernu, 08-21-2000 06:31:24
Get some sea foam put some in the gass and some in the oil it will free carbin and remouve the sledge run smouther and it cleans the rings i used it on my international c
The Red
08-21-2000 07:49:25
Cory the only thing I can think to do is turn the idle screw counterclockwise until it is running rough then turn it in until it smooths out. Did you replace the idle metering jet?
Cory
08-21-2000 08:00:29
 Re: Re: '41 still smoky in reply to The Red, 08-21-2000 07:49:25
I replaced the idle metering screw. Is that the jet? Could the float setting have any influence on this? Is it possible on such an old tractor to eliminate all smoke? Even when throttling up?
Traktrmn
08-21-2000 19:21:04
 Re: Re: Re: '41 still smoky in reply to Cory, 08-21-2000 08:00:29
Cory: When you get frustrated enough with your
carb problem, (believe me, I've been there) pack
it up and send it to Denny's Carb Shop, 8620 Casstown-Fletchter Rd., Fletcher, Ohio 45326.
phone: 937 368-2304. I just got a carb back from
them, and it made all the difference. He's not
cheap, but he's good.
The Red
08-21-2000 09:04:42
third party image
The idling jet is the one with the tiny slot in that slender assembly that is threaded on the bottom. Float assembly should look like this with the needle closed.
Cory
08-21-2000 09:17:10
 Re: Re: Re: Re: '41 still smoky in reply to The Red, 08-21-2000 09:04:42
That's the one that I found was completely plugged. I carefully removed it and pushed the plug out with the proper diameter wire and soaked it in carb cleaner. The carb kit did not have a replacement so I put the old one back in. Can you order just that part? Perhaps in the process of unplugging it, I enlarged the opening?
The Red
08-21-2000 10:41:54
 Re: Re: Re: Re: Re: '41 still smoky in reply to Cory, 08-21-2000 09:17:10
Sorry. Work is interfering with important Farmall problems! I would suspect that is where the problem lies. Call Ken Updike but I really doubt you can get just that item. 608-455-2411.
Cory
08-21-2000 09:16:22
