C/Super C Farmall Question
LWW
Does anyone know the bolt size for the three holes in a triangle on each side of the front of the tractor for mounting cultivators? Any help will be appreciated.
They were special bolts with the under side of the head rounded. I'll look in the morning but think the bolts are on the order of 3/4 fine. Someone else will probably know the exact threads. Been many years since we've had the culti. on the SC.
As others have said, 3/4" coarse, I believe. The back of the head was tapered to help line things up and firm up the attachment, but I would think you can get the job done with a regular bolt and a lock washer if needed.
(quoted from post at 08:36:56 09/14/11) As others have said, 3/4" coarse, I believe. The back of the head was tapered to help line things up and firm up the attachment, but I would think you can get the job done with a regular bolt and a lock washer if needed.
The mount on the cultivator was "double drilled" with a hole large enough to fit over the bolt head, then slid to the smaller 3/4" hole which was countersunk to match the tapered back side of the bolt head. I'd bet the bolts are still available from a dealer. If I remember right, one end of the wrench that came with the tractor fit the bolt head.
