I was told that a 140 crank will not work with super A
I have a 130 block.
A 140 cam
A 140 crank
I was told today that the Super A pulley is different than the 140 pulley.
Is it possible to have a Super A pulley on a 140 crank? Do I need to find another solution?
The pulley for a Super A will not work on a 140 crank & if you use a 140 pulley the belt will not line up with the fan pulley for a Super A, 100 or 130
We've been taking a close examination of the cranks and pulleys. I need pics, but it looks like it may work.
Here is where we are leaning.
A 140 crank will work with a Super pulley, but a Super A crank will not work with a 140 pulley.
The 140 crank is a little longer with a threaded end made for the nut that screws down the pulley. The Super A pulley looks like it might slide over the threaded part and still be able to be pressed on the 140 crank.
I'll keep you updated. I may be going into Farmall restoration territory that has never been done before.
