Coolant hose for 806
LDP
I just got an 806 and it is leaking coolant from a short hose near the waterpump. I went to order it and found I cannot get it. The dealers answer was buy a piece of 1 3/4" hose. But the parts book said it is 1 3/4 x 2 1/8 x 3 1/4 inches long. After I was told that I looked at the hose on the tractor again and it looks like it was cut to fit over the bigger pipe. Has anyone had this problem? What is the best way to correct this. Thanks.
I go to the NAPA store and walk through the Hoses on the hangers. I always find the correct bend , reduction or configuration I need even if it is in the middle of a longer more bent hose. I never ask what it fits on, I just buy it cut it and go. Jim
(quoted from post at 11:02:21 09/02/11) I just got an 806 and it is leaking coolant from a short hose near the waterpump. I went to order it and found I cannot get it. The dealers answer was buy a piece of 1 3/4" hose. But the parts book said it is 1 3/4 x 2 1/8 x 3 1/4 inches long. After I was told that I looked at the hose on the tractor again and it looks like it was cut to fit over the bigger pipe. Has anyone had this problem? What is the best way to correct this. Thanks.
It is a straight hose. 1 3/4 ID, 2 1/8 OD, and 3 1/4 long.
Thanks, I thought it was one size on one end and different on
the other. Thank you.
