560 hydraulic level help.... thanks!
colby64
Im going to polish my hyd levers, how do you get them apart??
I have removed the set of levers off the tractor.
thanks
If you are talking about the ones in your picture, It looks like there is an end cap on the right end of the set of levers. Pry it off with a screwdriver and there should be a nut inside that you take off and they should seperate. Used to have them on my tractor but I never took them apart.
we have already tried to get them apart.... after removing the end cap we did get the shaft out but the levers wont come apart.
Looking at the parts cat. it appears there are three or four snap rings that hold things together.
Enter 560 gas....hyd. system....group 221 (third down) for the blow-up.
CASE PARTS
