farmall h stepped head pistons
lee oh
took the head off my h today to give a valve job and noticed it has stepped head pistons and a 3 3/8 bore. with a good valve job what power should this be making, was 22 before the valve job
22 is low for stepped head pistons.
Be sure your timing and advance are working as designed. Also adjust the carb on the dyno under load. It should make 25+ Jim
i had hoped 22 was low. had everything adjusted perfect but the valves were pretty bad had almost a dead cylinder
