Seal replacement ,shafts where brake disc ride Super M
mike1972chev
Here I am again,
Since I am working on my brakes,How hard is it to install new seals on those splined shafts where my brake disc spline on them ????
Not hard, if the covers are off use a slid hammer in the threaded hole in the end of pinion shaft. Plate inside disc contacts will come out with shaft. Seal is in the plate. Plate can also be pried off. If you look close cut outs to get a pry bar in can be found on the outer edge and back side of the plate. Needs to come out pretty even. Plate will have a o ring also.
