656 utility
Anonymous-0
has anyone had experiece with a 656 hyd system causing the loader to jerk and fade out only when the clutch pedal is pushed down? the hyd filter and oil has been changed and the right amount of oil is in the transmission,also the power steering is jerky. the loader and steering works great until you push down the clutch pedal,then it acts like the hyd pump is sucking air or running out of oil,thanks for any help,Farm-Al
The splined drive for the hydraulic pumps and PTO is probably worn out. When the clutch is pushed in the crank end play, and metal flex combine to allow the most worn spot to slip. A split is required. This is my best guess, as it is the only thing in that assembly that could be affected by the clutch. Jim
