Just purchased a 1980 1486- had a 1466 but wanted a factory cab. Have a couple of questions I would like help with:
None of the lights work except the two rear flood lights- checked the fuses and they tested Ok- any quick place to check before starting to look at the whole harness?
How does one get a SMV to stick to the fuel tank- cleaned the tank with simple green and then acetone but the adhesive SMV won't stick- what is the trick?
Thanks in advance.
Thanks in advance.
