farmallboy15
ok i figured out what was causing the fuse to blow, there was a open wire inside one of the lights. but i still cannot figure out why the generator is not charging.the gen is good. i have spark when i jump the hot terminal to the ground. i also have all connections on gen cleaned up. it has a cut out relay and 4 position switch, all wired correctly. i have light box to steering post to rearend connections clean. i was able to follow all of john t's diagram to the grounding the light switch, what part needs grounded? is there something im missing?with good gen, good switch, good ammeter, good wiring, good battery im still not getting a charge... thanks
