Farmall 100 hyd update
well I got it to pump and lift the loader and rear fast hitch but after I lift the loader and let it down there isn't enough fluid left in the touch control. I filled it 3 times and it does the same thing, now am I still low on fluid or is it just putting it back in the loader resevour? Seems like it isn't getting fluid back into the touch control unit. any ideas?
Chad
Check your engine oil, it is what you do not want to do, but ---could be---.
The return from a cylinder must get back to the touch control reservoir. If it is going somewhere else, find that location and figure out why. Jim
I had a loader on my Super C in the past. Do you have an extra tank for additional fluid? My set up had a tank that screwed into the fill spout on the Touch control hydraulics and sat up above the fill hole. This extra capacity hyd fluid tank then had it's own fill cap on top.
Looked original to me and came with the loader. Looked like a football in shape.
Chad I just put one on a SA few days ago, it had a fill plug on the front toward the top of the resivior on the loader, I filled it with the loader in the down position and filled the touch control, worked the the loader a few time and refilled it, repeated that 2 to 3 times until they both was full, it worked ok for me. Good luck
I just did the same thing as you discribed I read the book on the touch control pulled the levers back and filled that the way the book said. then I filled the tank on the loader and it worked good I will re-check them again in the morning after I run it a few more times I am so happy its been a long few days.
