IH 202 Engine?
JoeStreb
hello my dad has a engine that he was going to put into a air compressor that he said was out of a old IH haybine or something and he said it was a model 202? im wondering if they put those in any tractors or if we even have our information right... he never finished the compressor and is going to scrap it but the motor still is good and i was wondering if i could put it in a tractor... thanks for the help
A 201 windrower has an engine that matches a C, oe SC. It may be of a variety of sizes including 113, 123, 135, 153, or others maybe.
There are other windrowers, but any in the IHC, (not CaseIH) will probably have that engine, but the Crank shaft and front cover will be different. The crank will not be drilled/bored for the pilot bearing used in a tractor, and the starter might be front mounted (reversed direction) in the power unit engine. I could find no 202 windrower. Jim
ok thanks i got soe info of the block its stamped 400336 R1 amd under that it had a 9 9 R idk if that helps IH's are new to me
