Tractor seemed like the clutch was slipping a bit, (but couldn't smell clutch) so I went through and adjusted the clutch and the TA according to the service manual. Seems to have improved the slipping , but now when I push in the clutch to stop movement of the tractor, the tractor almost stops, then suddenly has a quick lurch forward with a knock type noise, then comes to a complete stop like normal. (If I pull it into neutral as soon as I depress the clutch, it doesn't do the lurch or knock) Any ideas as to what to try and adjust next? possibly the clutch brake?, although I did adjust that when I did the clutch and the TA, but is that where I guy should start checking again?
